Web Solutions for Microsoft
Dynamically publish documents from SharePoint in context to the Web. Documents and metadata can be easily selected to be integrated and published onto your online media.
Information should be accessible via the Web, independent of its storage location, but still targeted to the right audience and different online destinations to achieve consistent information transparency. Open Text Web Solutions for Microsoft creates the foundation for publishing company content on the Internet, intranet, or extranet in the required context easily and securely. Information portals combine content, documents, and applications from a range of systems. With Open Text Web Solutions, you can flexibly use documents administered in Microsoft SharePoint in all online media. Additionally, Open Text Web Solutions adds content management, personalization, and applications to the Microsoft SharePoint portal range of functions.
Use of Documents Across All Mediums
Editors can use documents required for the Web straight out of SharePoint. The integration solution does not require a laborious transfer to Web editors as they can integrate the documents and information seamlessly and independently from the repository. SharePoint content can either be linked or saved as a copy in Open Text Web Solutions. The more suitable form of integration can be used depending on whether the environment is public or protected.
Direct Document Access for Web-Page Editors
If SharePoint is used as a central repository for information, this content can be used in all online media, at the push of a button, in Open Text Web Solutions. This enables the editor to access SharePoint via a Web-based interface, to research the information there, and to link this to his or her own content. Internal SharePoint release processes ensure that the information is kept up-to-date.
Automatic Compilation of Result Lists
The search functions available in Open Text Web Solutions enable result lists to be created and displayed in any form of online media (Web sites, intranets, extranets, and portals). This allows for the rapid publication of entire document lists. To be able to update search results quickly and reliably, you can save the predefined search criteria in "saved searches" and run or change these when necessary. The documents that are found can be sorted by attributes, limited to a certain number of items, and later published to any Web page.
Multifunctional Content Usage
Content created with Open Text Web Solutions can also be used in the portal (Microsoft Office SharePoint Server 2007). Intelligent and personalized delivery enables the display of specific content, customized for the user, and in the context of the portal page. Furthermore, content from other systems can also be displayed in Microsoft SharePoint using Open Text Web Solutions. The added value of the Microsoft SharePoint portal increases, and the users are able to find the information they need from dispersed systems faster.
Contact an Expert
STA Travel
sta_travel_image
STA Travel enriches its customer Web offering with Web Solutions, offering a targeted experience with Web 2.0.
Intuitive Content Authoring
Quick Tour
Let the content experts update and manage your sites.
Localize Your Content
Quick Tour
Manage sites with a translation environment designed for multilingual sites.
Go Global with Ease
Quick Tour
Quickly and easily expand your global reach.
Web Solutions for SAP
Leverage your investments in SAP NetWeaver Portal with WCM from Web Solutions.
Main Navigation
Select Region
English
United States (English)
Canada (English)
United Kingdom (English)
Australia (English)
Mexico (English)
German
Germany (German)
Switzerland (German)
Austria (German)
Poland (Polish)
Brazil (English)
